| | | Forums66 Topics128,095 Posts1,056,067 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2014 Posts: 164 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 164 | My '53 3100 didn't have turning signals so the dealer added big round signals on top of the front bumpers and on either side of the tailgate. Is it possible for me to wire them into the front parking and rear tail lights so I can remove those big fixtures? If so, how? Thanks
~Denny 1953 Chevy 3100 w/1960 261 cid, 848 head | Weber 32/36 progressive 2 barrel carb. | Three on the tree & 3:55 torque tube | 12 V w/Gener-Nator & 6 V starter In the Gallery Forum1998 Chevy Suburban 350 ci awd/4wd | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes it can be done - the front needs 2 separate circuits, so dual filament bulbs in 2 pin sockets - the rear signals use the brake filament, which may need a change in the way the existing switch is wired, or even a different switch .... here's the TF series wiring for the setup you have .... here's the wiring when using the park/brake lights instead Bill | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Nov 2014 Posts: 164 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 164 | Thanks, guys. The front looks like a simple job and I've ordered the conversion kit that Tim suggested. The rear looks tougher and I wonder if there's a similar conversion kit available...?
~Denny 1953 Chevy 3100 w/1960 261 cid, 848 head | Weber 32/36 progressive 2 barrel carb. | Three on the tree & 3:55 torque tube | 12 V w/Gener-Nator & 6 V starter In the Gallery Forum1998 Chevy Suburban 350 ci awd/4wd | | | | | Joined: Dec 2002 Posts: 3,441 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,441 | I bought a decent quality set of trailer lights and robbed the internals to make my tail lights all internal in the stock (repopped) housings..
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | As stated above. if you want the rears to use the same lights as brake and tail you will need an switch designed for such. The switch for separate lights can not be wired that way. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | If you get a trailer, you need to be aware of how you did your truck so they match up.
Ed
| | | | | Joined: Sep 2002 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2002 Posts: 62 | I’ve used this Turn Signal Kit 12 Volt from Jim Carter in my ’53 3100. It has everything you need to convert the original light housings as well as everything else you need for the turn signal and instructions. It’s a little difficult to install, but when you’re done, you won’t see any visible difference. The switch is a simple left-off-right toggle switch. You have to turn it off after you’ve completed your turn. I installed it under the dashboard directly beneath the gauge cluster. You can’t see it, but it’s very easy to find without looking. It recently stopped working, but that was because the connectors had come loose from the switch. I replaced the fork connectors with ring connectors which should hold until the screws actually fall out. You might want to do this when you first install the turn signals to avoid possible future problems. | | |
