1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 35 Shop Shark | | Shop Shark Joined: May 2008 Posts: 35 | Hey all - did a search and could not find. Does anyone have a complete/almost all original 248 photo they can post? Or better yet, an engine schematic image? | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | All GMC's of this vintage look pretty much the same on the outside except for military 302's
Ed
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | All GMC's of this vintage look pretty much the same on the outside except for military 302's
Ed Thanks, Ed If that is correct, maybe the photos in this 55-59 GMC Maintenance Manual will help? I do not know about the 1954 GMC small truck front motor mount, but the rear motor mounts should be the same (as the 270 in the 55-59 GMC MM). | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The '54 front mount is the same as the Chevrolet mount, on the lip of the timing cover plate. | | | | | Joined: May 2008 Posts: 35 Shop Shark | | Shop Shark Joined: May 2008 Posts: 35 | Thanks. Was looking to see how the gas lines ran. I am thinking about replacing the tube type gas line for the metal lines. What are the pro v. cons of doing this? | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | The front mount is not always the same on GMC's; all my 302's have a fabricated U shaped channel, flat on the bottom, that rests on rubber in the front, like in the maintenance manual in above message, the frame mount might be the same for both engine mounts, I do not have one to look at.
Ed
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | GMC Blue chip used the fabricated U shaped channel. 248, 270 and 302 used it. Earlier engines including the 302 used the front plate mount and are not drilled for mounting the U shaped channel. | | |
