0 members (),
128
Mod | | | Forums66 Topics128,167 Posts1,057,021 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 12 New Guy | | New Guy Joined: Dec 2005 Posts: 12 | I have been struggling with the installation of fender welting on my 52 chevy pickup. Does anyone have any suggestions on how to get a decent body line without cutting the welting to shreds? I have tried the multiple triangle cuts but was never happy with the welting line. I tried a new roll of fender welting and tried some rectangle cuts and that helped somewhat. I was just wondering if anyone had an easier method or tricks that have eluded me here. Thanks in advance for any ideas folks.
Trace
chevy52
| | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | I just layed the welting on the rear fender. I drew on holes where the holes were. Drilled the holes in the welt. Bolted it all on. One of my holes was a little bit off so it sitcks up maybe and 1/8 of an inch above the fender edge. Still looks fine. Worked for me and was easy. Best of Luck. | | | | | Joined: Oct 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 275 | What I did was with the fenders off the truck laid them flat and used glue and glued them into place made cuts where I needed to, cut the holes in place worked great.
38 original 48 panel 59 stepside 46 in the back forty
| | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | Cut triangles at bolt holes,slide in welting and tighten fender bolts.Then at he ends of welting where you cut off roll put some weather sealer on cut ends .This will save you future problems down the road.
dan-pa
| | | | | Joined: Dec 2005 Posts: 12 New Guy | | New Guy Joined: Dec 2005 Posts: 12 | Wow...you guys are fast. Thanks so much for the ideas. I am heading out to the garage to give it a whirl. Thanks again.
chevy52
| | | | | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | Warming up the welting will make it earier to work with. The original welting on my truck was notched with triangles and glued to the truck.
1954 GMC 1/2-ton Longbed 1971 Pontiac LeMans Sport
