3 members (Gdads51, Raymond HAYWOOD, IHPWR), 175 guests, and 2 robots.
Topics128,088
Posts1,055,993
Members48,430
#1188076 10/24/2016 5:19 PM
Hey all - did a search and could not find. Does anyone have a complete/almost all original 248 photo they can post? Or better yet, an engine schematic image?
When you find yourself the victim of someone's bitterness, ignorance, smallness or insecurities, remember it could be much worse - you could be them.
https://www.facebook.com/Bluebird-Screen-Printing-245546842130721/
Crusing in the Passing Lane
All GMC's of this vintage look pretty much the same on the outside except for military 302's
Ed
Ed
Thanks, Ed
If that is correct, maybe the photos in this 55-59 GMC Maintenance Manual will help?
I do not know about the 1954 GMC small truck front motor mount, but the rear motor mounts should be the same (as the 270 in the 55-59 GMC MM).
The '54 front mount is the same as the Chevrolet mount, on the lip of the timing cover plate.
Thanks. Was looking to see how the gas lines ran. I am thinking about replacing the tube type gas line for the metal lines. What are the pro v. cons of doing this?
The front mount is not always the same on GMC's; all my 302's have a fabricated U shaped channel, flat on the bottom, that rests on rubber in the front, like in the maintenance manual in above message, the frame mount might be the same for both engine mounts, I do not have one to look at.
Ed
GMC Blue chip used the fabricated U shaped channel. 248, 270 and 302 used it. Earlier engines including the 302 used the front plate mount and are not drilled for mounting the U shaped channel.
