1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#1185450 10/04/2016 8:22 AM
I have a Chevy 1941 YR open express truck that I'm starting to plan the restoration.
It's not clear to me if this truck is 1 ton or 1.5 ton.
What would be the best forum for posting questions?
-- Scott
ScottSewall #1185457 10/04/2016 12:43 PM
Crusing in the Passing Lane
Wheels might be a start. 20" would indicate 1.5 ton, 18" might indicate 1 ton, 16" could be 3/4 or 1.
Ed
Start here and when you figure out just exactly what you have you can post further questions in the appropriate forum. Sounds like a really cool project.
The rims measure about 21" across, so it looks like I have 1.5 ton.
So,
What is the bolt pattern? Then one can determine what modern wheels will fit.
Ed
I have some pictures of the truck on facebook, where you can see the bolt pattern for both front and rear.
https://www.facebook.com/media/set/...001979945131&type=1&l=584e699e2d
I like to look of the old rims and hope that I can keep them.
ScottSewall #1188051 10/24/2016 12:56 PM
Looks like 5 on the front, probably 10 on the rear, commonly referred to as 5/10 on 7.25" circle. When tubeless tires first came out in late '50's, they made 22.5 tubeless wheels with this pattern, they will hold up to 9 x 22.5" tires. Hard to find, found on farm trucks, among others, of the era.
Tubeless tires are worth considering because many tire shops will not or cannot deal with them.
Nice truck, do you know any history?
Ed
ScottSewall #1188114 10/25/2016 12:28 AM
If you find 6 new 22.5 tires I'll give you a $500 bonus.
Evan
That's a beauty. I love those open express trucks with the long bed and big wheels.
You going full restore? I think it looks cool like it is.
1951 3100
EdPruss #1188909 10/31/2016 7:25 AM
I don't know much history of the truck. I bought it from a fellow in Ottertail MN, who picks up and sells old trucks he finds in the Dakotas, Montana, and Wyoming. He told me the truck came from a ranch where it was used for haling a large water tank.
JW51 #1188910 10/31/2016 7:34 AM
I like the character of the patina and plan to keep that as-is. I'm currently working on updating the drive train. I have a rebuilt 235 to start, and am looking for ideas for transmission and differential that would allow me to drive higher speeds, perhaps 60 or 65.
ScottSewall #1189071 11/01/2016 12:52 PM
If you wish to keep that wheel bolt pattern, it has been used by GM for a long time, however, axles might be too wide. Grigg has discussions about putting modern spindles on an original front axle, including disc brakes. Look for 3500 HD GM trucks for that bolt pattern. Rear axle would be Dana 70 or 80.
Modern axles come with 19.5 wheels which look undernourished on that truck. A gentleman in AZ had a wheel shop put 29.5 centers in modern 22.5 wheels, no idea how mosh they co$t.
If you use smaller bolt pattern, filling wheel wells becomes a problem, OD of tires is smaller.
Ed
