1 members (Cletus1950),
77
Mod | | | Forums66 Topics128,151 Posts1,057,000 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | ok, I will stay off topic too... what ever happen to WD-40 I dont understand why this topic is a pre 73 truck question to start with yr ago , but it is an example of speaking of a CAR engine that has been in question..
Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | I've used PB Blaster, WD-40 and Kroil. Found a product that I found beats them all. Deep Creep by Sea Foam. This stuff will break loose rust, carbon, tarnish and even stuck on 216 cu.in. vibration dampers. It also leaves a rust inhibitor coating on the metal! Was also able to get a Gravely 44Z riding mower drive pulley loose from the crankshaft that had so much rust around it and in between the pulley and shaft that it was almost rust welded to the crankshaft. Deep Creep and a few passes with a propane torch and it came loose. Just another suggestion....
Tim
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: Oct 2016 Posts: 3 New Guy | | New Guy Joined: Oct 2016 Posts: 3 | I cancelled my amazon.com order & will wait for one of Kanolab to offer their 2 for 1 SALE....& then stock up. | | | | | Joined: Oct 2016 Posts: 3 New Guy | | New Guy Joined: Oct 2016 Posts: 3 | I'm going to try 50% ATF & 50% Acetone, a combination that has received a lot of mention on youtube when comparing penetrating/loosening products until KaroLabs has their 2 for 1 SALE. | | | | | Joined: Mar 2010 Posts: 10,303 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,303 | I have tried the 50-50 ATF/acetone combination but could not get them to mix together. It was like oil and water. Anyone else have that issue? Is there a specific type of ATF needed?
Last edited by 52Carl; 10/20/2016 1:08 AM. Reason: deleted the word fluid which I erroneouslly added following ATF..
