0 members (), 171 guests, and 2 robots.
Topics128,143
Posts1,056,494
Members48,442
#1187355 10/18/2016 9:22 PM
I've got a 50 chevy 235 engine. The exhaust manifold is angled and i have a flat flange (no round dougnut gasket) between the exhaust manifold and exhaust pipe. There's a flat gasket between the two is that the way it should be? Or should my exhaust pipe be flared and have the doughnut gasket spacer between the two? Any pics available?
Dan
Dan, both types of gaskets and flanges can be used.
If you have a flat flange on your exhaust pipe, you'll want to use a flat gasket.
You'd want to use a donut gasket if you had a flared exhaust pipe/flange.
The donut set up give more flexibility to adjust the exhaust.
There are many opinions about which one is best. Both work.
Matt
just curious back in 1950 how did the truck come off assembly? Flat flange or donut gasket?
I used Fel-pro 60052 gaskets on my Fentons with no ring cut for donuts and flat flanges on the pipe. It has a crush ring built into the gasket. The flat gasket would probably work if everything is aligned right.
My problem was shoddy workmanship by the muffler shop that did my pipes. After a couple of hundred miles my gaskets blew out. Since my fix I have put about 25,000 miles on it with no problems. If interested you can read about the problems and the fix here.
Crusing in the Passing Lane
Just make sure to use brass nuts(no monkey jokes here) so they can be taken apart someday.
Ed
