1 members (Truckrolet),
154
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | I will be mounting my son's 1946 235 onto a 1945 rolling chassis. I did not pull the engine so I need to figure out what and where fasters are used.
Rear Mounts
I got new rear motor mounts from Rock Auto. My question is do I use any flat washer and or lock washer under the bolt heads when attaching the mount to the block?
Do I use flat washer and or lock washer between the frame and the nut?
Bolt dia" and length?
Front Mount
How to position the metal piece sits below the top piece/oil shield and the rubber bushing is flat except for along one of the long sides.
That side of that flat metal piece is curved downward. Does that long side with the curved edge face the radiator or does that curved edge face the engine. Jeffrey | | |
