| | | Forums66 Topics128,006 Posts1,055,268 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2015 Posts: 19 New Guy | | New Guy Joined: Aug 2015 Posts: 19 | I have a 51 3100 with what I think is a mid 60s engine and trans (casting numbers). When the switch was made, I assume the truck was converted to 12v at the same time. It's running an external regulator. About a year ago my gauge was showing random charging in 1v increments. Took it to autozone, tested, and it was the voltage regulator. No problems for a year. Recently the gauge is showing 11.5v. Replaced the alternator and no change. Checked voltage at alternator 11.5v. Bench tested alternator at parts store, tested good. Replaced voltage regulator, no change. Had truck tested at parts store, faulty regulator. Replaced regulator, no change.
So any thoughts? 2 bad regulators in a row?
I could swap for a 1 wire, but I'm invested with the setup now.
Thanks in advance
Ryan | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Bad regulators not uncommon these days!
| | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | My father had a saying- - - -"Getting repair work at a service station is like getting brain surgery at a drug store!" In the same general train of thought, getting electrical diagnosis from some computer jockey at a parts store makes just as much sense. Find someone who can follow a wiring diagram and see if all the circuits are intact. Use a wiring diagram for a late-1960's or early 1970's GM vehicle with the "Delcotron" external-regulated alternator, and duplicate the circuits exactly.
Converting to an internal-regulated 10-SI alternator would be a far better choice. Jerry
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | A 10 SI cost around $40.00 with core around here. To get a running truck for $40.00 ain't bad. BUT, as Jerry stated. Your problems very well my run deeper and a knowing 'set of eyes' would help. Reach out to that electrical guru down the block.
| | | | | Joined: Aug 2015 Posts: 19 New Guy | | New Guy Joined: Aug 2015 Posts: 19 | Thank you guys for the info. Always good stuff here. I think I'll go with a one wire. Going to see if the place I purchased the alternator will work with me on a swap. I really don't know anyone with the knowledge I need to fix the current setup, running a 3 wire with diode/light is more work than the one wire. I know there are pros and cons to 1 vs 3...
Thanks again.
Ryan | | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | Take a look at Fifth Ave. Garage Randy Rundle is an alternator guru. He carries 6 and 12 volt and with his alternators you don't need to rev your engine to get them charging. Plus he's a great guy to deal with! Lots of great info on his site. Steve
| | | | | Joined: Aug 2015 Posts: 19 New Guy | | New Guy Joined: Aug 2015 Posts: 19 | Parts store swapped me for a 1 wire straight across. Truck is charging at 14.68 at the alternator.
Hopefully this fixes it. Thanks again for all the info.
Ryan | | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | Check the battery terminal voltage, not at the alternator. With good connections and the right gauge wire, you should see 14.5 or better against a fully charged battery, less if the battery is low. Jerry
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Can you put the old wide generator pulley on that 10SI? | | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | There are pulleys available for tractors that run the wide belt. Check Ebay for "wide belt alternator pulley". It's a quick swap with an impact wrench- - - -no Woodruff key, just a friction fit. Jerry
