1 members (Hotrod Lincoln), 60 guests, and 0 robots.
Topics128,050
Posts1,055,641
Anyone have problems getting the inside door handle latch to engage the door lock? I can't seem to get the door handle to release the lock?
These are all new after market parts
Thoughts?
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
I'm thinking that your 1960 latch might be different than my 1965 latch. Are you saying that the LINKAGE from the inside door handle is not functioning?
OR
Are you saying the piece on the door won't properly connect to the piece on the door frame (cab)?
Ok,we think we figured out what the problem is. The OEM door release is operated by a spring and moves the linkage forward and backward. The NEW aftermarket setup DOES NOT move the linkage forward enough to trip the release spring on the door lock. I had one OEM linkage for the passenger side and it works perfectly.
Side by side they are identical, but the spring just does not work correctly. It's possible that the springs is just too hard/tight, but you are taking a chance of striping the teeth off of the new shaft part (trashy soft metal). I see now way to adjust the spring.
I reached out to RJ Sisneros in Colorado for a OEM linkage.
http://i1299.photobucket.com/albums/ag64/jbgroby/IMG_20161008_090049220_zpsqagr1wjl.jpg
Jake
