9 members (Gdads51, rfs56trk, FAST55, HandyAndy, 3B, Shade Baby, Hanks custodian, Wally / Montana, Otto Skorzeny), 51 guests, and 1 robot.
Topics128,038
Posts1,055,584
#1185894 10/07/2016 11:50 PM
This a real simple question. The wipers on the 52 chevy, is the switch directional, left right with a manual to move back and forth or is the motor able to recycle like todays car wipers? My wipers work well but its pretty hard to steer and trigger the wipers engaging one cycle left than turn the switch to other direction.
Rich 1952 #1185905 10/08/2016 2:22 AM
The original vacuum wiper and switch were on/off.
When on, the wiper blades move back and forth - somewhat continuously (but slow down/stop when the engine vacuum is low).
It sounds like your vacuum wiper "motor" needs to be rebuilt - http://www.wiperman.com/, or cleaned, or lubricated.
From an article by Bob Adler in October 2004. Vintage Truck:"Make Components Last Longer"
"Vacuum wipers aren't known for Herculean torque, but you can grow fond of the hissing and flip-flop sounds vacuum motors make. Periodically, squirt some motor oil into the wiper-motor air intake (a pinhole near the valve-tripping mechanism, not the rubber hose going to the intake manifold) as the wipers are operating. This will help to seal the moving paddle to optimize power.
http://1954advance-design.com/Web%20images/wiper-motor-lubrication.jpg
Rich 1952 #1185955 10/08/2016 3:57 PM
Took your instructions and it worked, going to make it a note for future service. thank you
