3 members (Nick in Manitou, 2 invisible), 57 guests, and 1 robot.
Topics128,109
Posts1,056,572
Members48,448
#1185248 10/03/2016 2:06 AM
Well, I finally got the top end rebuilt on my 270, had a friend help me to set the carb and we got it runnin half way decent... I was SO excited ! But then elation turned to sadness when we discovered a water leak near the front of the engine. It didn't really show itself until the motor got warm. I refilled the radiator today and fired it up. It didn't run near as smoothly today as it did yesterday. I tried driving it in the yard and it kept bogging down like it has in past before I had it rebuilt. Even worse, it was pouring water from water pump
after just a few minutes running today. I guess I will be needing a new water pump now at a minimum ? Are they out there anywhere ? Very expensive ?Any input appreciated.
Troy
Troy
1963 Chevy C60
Big Red Chevy
1951 GMC 453 Series 3-Ton Army Truck
They are available on eBay all the time. Kits are in the $65 range and new pumps are about $140 and up.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thanks, Mike... I will check those out. Would a rebuild be easy enough to take on ?
Troy
1963 Chevy C60
Big Red Chevy
' Offline
Whats better than GM NOS ?
A brand new water pump will outlast a rebuilt pump.
Go to ebay & type in the search box...
NOS oem water pump...it should come right up.
A GM NOS water pump GM # 839012 is available GM NOS.
It comes with a new metal backing plate.
Looks like you will need to save or replace the two
backing plate screws or get new ones.
You will also need to save your old PULLEY
or find one GM NOS.
photo@photobucket
http://i669.photobucket.com/albums/...MC_839012_Water_Pump_NOS_zpsxnbnuqld.jpg
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
