3 members (Guitplayer, moparguy, GrandpasJimmy), 137 guests, and 8 robots.
Topics128,183
Posts1,057,264
Members48,467
DLBrooks
DLBrooks
This may be hard to get me an answer unless we can measure decibels, but I have a 54 - 235 -- hydraulic lifter engine. I did adjust 2 lifters and I have no hood on the truck yet. I may give all a half turn and see how it sounds. Lifters may have a problem but the engine does seem to run ok.
If you say no noise, I have a long way to go.
I am going to the Pumpkin Run today and maybe I can listen to another. I have not had an inline 6 for a while.
1959 GMC 100 Fleet
Follow in the DITY
First, examine the undersides of the rocker arms where they contact the valve stems. It's pretty common to find them worn concave so it's difficult, if not impossible to get a good adjustment- - - - with solid or hydraulic lifters. Yes, hydraulics should give virtually silent operation, as long as they're in good condition and adjusted correctly.
DLBrooks
DLBrooks
Will do.
1959 GMC 100 Fleet
Follow in the DITY
We use a piece of rubber hose or tubing with one end moving around the engine, the other to our ear. Listen for ticks or whatever under the valve cover. Others use a dowel or broom handle. You will hear things as there is a lot going on under there.
Another thing I did to get a better handle on any problems was to cut an old inline valve cover so the sides were still there but the top was cut out. I could watch the whole operation with the motor running and not get oil everywhere.
