| | | Forums66 Topics128,110 Posts1,056,242 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2014 Posts: 307 'Bolter | | 'Bolter Joined: Aug 2014 Posts: 307 | Installing a radio in my 12volt 53 1/2 ton. Would like to install a inline fuse and not certain of fuse amp. The specs show 10 amp for the line to the battery and 1 amp to the ign. Thanks, Scott | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If those specs came with the radio, that's what you use. It doesn't sound right though. I can't recall ever using a 1 amp fuse. Usually about 4-6 amps on the aftermarket radios.
They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2014 Posts: 307 'Bolter | | 'Bolter Joined: Aug 2014 Posts: 307 | Thanks. That is what the specs say in the manual- Custom Auto Sound. I put an inline fuse to the battery should I also put one on the line to the ignition? If I am using 14g wire is a 7.5amp fuse ok for battery line? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I am going to guess that the radio has digital pre-sets and therefore there is a feed from the battery. That would be where a small fuse would be used. That feed keeps the memory alive. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It seems weird but I would do what the directions say. Like Nix I would think the small fuse would be the bat feed to keep memory & clock. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | it may be that the 1A line is only a trigger to turn it on (like the remote power wire (blue wire) for most amps and crossovers in car audio)It basically just activates a relay to turn it on. | | |
