8 members (66flea, asilverblazer, J Lucas, Otto Skorzeny, tclederman, Hotrod Lincoln, klhansen, 1 invisible), 136 guests, and 3 robots.
Topics128,185
Posts1,057,294
Members48,467
V
V Offline
I have a copy of the Borg Warner R10 overdrive Service Manual and Operators Manual. They each have a unique wiring diagram and I'm wondering which one is correct. Perhaps the wiring was changed from 1955-1957? My question is in reference to the ground out wire that goes from the kick down solenoid to the distributor/coil.
In one it goes from the kick down solenoid to the dist. In the other it goes from the solenoid to the coil. Here is a picture of both.
2 wiring diagrams
Brandon
They are both the same. The wire is going to the connection for the points on one diagram, and to the coil on the other. But if you follow the wire, the connection is just on opposite ends of the same wire. It just grounds the points so the O.D. can engage.
Tommy
59 apache 1/2t
261 short stepside
The upper diagram - Figure 9 shows an early wire diagram, probably Ford. It has a separate switch as a reverse lock out not used on later versions. Tommy is correct, they both end up on the (-) side of the coil.
Fred
