| | | Forums66 Topics128,185 Posts1,057,284 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 90 Shop Shark | | Shop Shark Joined: Jul 2009 Posts: 90 | I have a copy of the Borg Warner R10 overdrive Service Manual and Operators Manual. They each have a unique wiring diagram and I'm wondering which one is correct. Perhaps the wiring was changed from 1955-1957? My question is in reference to the ground out wire that goes from the kick down solenoid to the distributor/coil. In one it goes from the kick down solenoid to the dist. In the other it goes from the solenoid to the coil. Here is a picture of both. 2 wiring diagrams Thanks, Brandon | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | They are both the same. The wire is going to the connection for the points on one diagram, and to the coil on the other. But if you follow the wire, the connection is just on opposite ends of the same wire. It just grounds the points so the O.D. can engage.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | The upper diagram - Figure 9 shows an early wire diagram, probably Ford. It has a separate switch as a reverse lock out not used on later versions. Tommy is correct, they both end up on the (-) side of the coil. Fred
