0 members (),
77
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 130 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 130 | I have a 49-3100 with a 55-235 engine. I don't drive truck in winter. I change oil in spring, mid summer and late fall. I use 10-30 synthetic oil. I have a oil filter and understand about 10% oil is filtered. What are opions on keeping or removing filter. | | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | If you keep an eye on the rubber lines to ensure that they don't blow out from degradation, you can keep the remote oil filter without worries.
| | | | | Joined: Sep 2015 Posts: 81 'Bolter | | 'Bolter Joined: Sep 2015 Posts: 81 | Hi Doug,
The way I see it, 10 % is better than nothing. There is a guy selling a full flow oil filtration kit to go on our old motors. Do a google search for Deve's Technical Network. He's got some cool things to spend our money on. I'm not affiliated with him, just found him searching the internet one day.
Steve
Steve
1946 1/2 ton
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I have a 49-3100 with a 55-235 engine. . .
What are opions on keeping or removing filter. The by-pass oil filter might filter 2%-10% of the oil as the oil passes by the filter; however, in a short period of time, 99%+ of the oil get filtered as the oil passes by/through the filter unit. Why not keep it? | | |
