0 members (), 93 guests, and 1 robot.
Topics128,055
Posts1,055,782
#118314 11/04/2005 9:01 PM
I will be getting my cab back from the blaster this weekend. The cab will be blasted and primed with epoxy primer.
Is the next step to go over the cab with seam sealer?
Bill Schickling
Bill Schickling
1940 1/2 ton, 1940 3/4 ton
My web page
#118315 11/04/2005 9:29 PM
I did all my bodywork and priming first and seam sealed everything a week before final paint
Stuart
#118316 11/04/2005 10:55 PM
Wurth Products makes a wonderful brush/paintable seam sealer. http://www.wurthusa.com/project/en/topnavi/home/startpage_1.html
ie you use a small paint brush to apply it && you can paint on top of it.
- Body Repair Sealers -
Anti-flutter Urethane Foam (Flexible & Rigid)
Euroseal Gel
Fender Tape
High Solid Seam & Joint Sealer
Quick Dry Adhesive & Sealer
Quick Seal Bead Tape
Seam Sealer Adhesive Flex
Seam Sealer Brushable
Seam Sealer Fast Cure Epoxy
Seam Sealer Pneumatic Gun
Seam Sealer Rubber Based Sprayable
Seam Sealer Self Levelling Control Flow
Seam Sealer Self Levelling Epoxy
Seam Sealer Urethane Based Sprayable
Sound Deadening Pads European
Sound Deadening Pads GM OEM
Jim & Caroline
