| | | Forums66 Topics128,071 Posts1,055,901 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2015 Posts: 135 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 135 | I know I placed the shift rod springs in a very safe place because I can't find them now that I need them. It's only been 14 months or so since I stashed them safely. Are these springs available? I have had no luck finding them at my normal online stores. Possibly find something that will work at local hardware store or FLAPS. Where did you guys find them? Also may need the spring in the shifter box that is on the column.
Jackie | | | | | Joined: Jul 2015 Posts: 135 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 135 | I am going to answer my own question!
Local Hardware store had the springs.....not perfect but should do what they are supposed to do.
Jackie | | |
