11 members (Eisenholtz, Gone, Peggy M, Donf, Otto Skorzeny, Wickedbass, Hawkman, NJC, GRNHydra, hdgeren, 1 invisible), 72 guests, and 2 robots.
Topics128,023
Posts1,055,370
Members48,420
#1181267 09/05/2016 3:51 PM
Not sure what to call it but the "arm" that makes contact with the starter "button"? is hitting the firewall. The truck starts fine but the arm hitting the firewall drives me nuts while driving, constant banging when I hit a bump.
Is there a way to adjust this "arm" so its farther away from the firewall?
I have tried to put a piece of rubber, tried different thicknesses, around the arm but that just causes the arm to stay engaged after I start the truck.
Thanks everyone. Brad.
Cadee #1181271 09/05/2016 4:18 PM
Are you sure the engine mounts are okay?
My Blog
Cadee #1181282 09/05/2016 6:15 PM
Are you missing a spring?
Cletis #1181307 09/05/2016 10:19 PM
No, there is a spring there. If I try a tighter/shorter spring, it will stay engaged after the truck is started.
I forgot to mention it is a 51 3100 with the O.E. 216 c.i.d.
Cadee #1181308 09/05/2016 10:20 PM
How do I know if the engine mounts and the tranny mounts are ok?
Cadee #1181335 09/06/2016 2:04 AM
The spring should be pulling the arm away from the button. I don't see how it could cause it to stay engaged if installed properly.
Cadee #1181338 09/06/2016 2:30 AM
Cadee #1181471 09/07/2016 3:08 AM
It is common for the frame to crack in that cab mounting area, allowing the cab to settle.
My Blog
Cadee #1181502 09/07/2016 11:03 AM
Have you examined the cab mount sheet metal, frame cab bracket rivets, and cab mount bushings? It sounds like the cab has settled to me. Do you also have body/cab interference issues with your clutch and brake peddles?
Lots more pictures
Cadee #1181528 09/07/2016 3:39 PM
I think you guys are right on the "cab mounts" issue. Unfortunately I do not have a hoist, I can jack it up in the driveway...what and where exactly should I be looking at?
Brad.
Cadee #1181537 09/07/2016 4:34 PM
There is a cab support just ahead of the battery on the outside of the frame. The rear engine crossmember is also attended to the inside of the frame in about the same area. I have seen seen many trucks with frame cracking in this area.
My Blog
Cadee #1181545 09/07/2016 5:03 PM
Ok, I'll take a look. I guess if the frame is cracked there, then the cab will not be properly aligned...or will be sagging causing the starter arm to make contact with the cab???
Does that make sense?
Brad.
Cadee #1181546 09/07/2016 5:16 PM
Either the cab has dropped or the engine has shifted to the rear some how. I do not feel there is actually a problem with the starter, but a picture may tell a different story.
My Blog
