| | | Forums66 Topics128,101 Posts1,056,180 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | a sleeve for the bolt and 2 washers on top | | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | now if you want the original barber shocks and can find them they can be redone,and if you want some pics of the original shocks and the bolts I can get you those as well | | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | maybe you don't like the rancho shocks I guess | | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | or they cost to much for you or the bolt needs to be special | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | JoeK: I never saw that you gave him the Part Number of the shocks in your pictures????? RS5000 is just the series.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2016 Posts: 19 New Guy | | New Guy Joined: Sep 2016 Posts: 19 | The reason I did not buy them the first time is the seller would never get back to me on the dimensions and the parts numbers were different then mine. But, I read what you said and just bought them blindly because you sound so sure, so when they get here I will do what I can to make them work. I do understand if they are both 3/4" then it is doable but again I have no way to know from his description or the pics. I am going out of town until next Wednesday picking up my new boat and bringing it to Bradenton FL. I can't wait! When I get back first thing I will work on the shocks and get back to you. I appreciate your time and sticking with it until I get it! Thank you! | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I just put new steering cables in my Ranger. Trucks can wait.  But what great news on the shock saga.
