4 members (Shaffer's1950, Hotrod Lincoln, 1955 1 Series, TexasA&M48Truck), 127 guests, and 3 robots.
Topics128,106
Posts1,056,213
Members48,436
Manual choke....Rochester B...235.. air mixture screw CCW is this the correct direction for lean? .....CW is this the correct direction for richer?....seen it done both ways out in the driveway...my vote is for CCW for leaning out the mixture of air fuel...maybe I'm wrong??? But he has sooty plugs his way...?
CCW is richer
CW is leaner
1 1/2 turns out is starting point.
1953 Chevy 3100
261 and SM420
53Chevy 3100
1953 Mack Firetruck
1972 Porsche 911
1986 Honda Goldwing
I swear somewhere here on the forums it was stated exact opposite ...in fact it stated screwing,"out the screw makes it leaner." ? Glad I didn't bet money. The article I read changed my mind I thought I was doing it wrong .....bad information.
Thanks!
CW tightens the screw until it bottoms out in the base of the carb...leaner
CCW loosens the crew until it come out of the base of the carb...richer
That's the way I understand it. I am new to this and could be wrong too!
1955 Chevy Cameo
235 engine
3 speed transmission
Carburetion specialist
Different types of carburetors handle the idle mixture control in different ways.
The Rochester B screw is located after the air and fuel are mixed, thus CW (in) is leaner, because CW reduces the volume.
Other carburetors (many older Zenith and some Strombergs) meter air with the screw rather than the mixture of fuel and air. In this case, CW (in) is richer because it reduces the amount of air.
And then you have the strange case of the two-barrel Schebler, which uses knobs instead of screws for the idle adjustment. One is right-hand thread, the other left-hand thread. Thus using one CW is richer, the other CW is leaner.
Rather than read what has been written, sometimes in error, on the internet; always best to look at the idle circuit on the carburetor in question. Easy to tell by looking how it is going to work.
Jon.
The Carburetor Shop
Thanks for your help as always...Jon...!
