2 members (latroca52, crenwelge), 149 guests, and 2 robots.
Topics128,196
Posts1,057,393
Members48,469
#1179133 08/21/2016 10:58 PM
1956 235 hyd lifters. After it sat overnight I noticed that a few of the lifters that were holding valves open had their plungers collapsed down. Is this normal bleed down from valve spring tension? Thanks in advance.
Completely normal.
My Blog
Lifter bleed-down is normal. All hydraulic lifter engines do it. If there's enough bearing wear and/or other clearance issues that result in low oil pressure, sometimes it takes a little while for the lifters to pump up and stop rattling after sitting for several hours.
Ok, that's what I figured, just wanted to be sure. Thanks again.
