| | | Forums66 Topics128,275 Posts1,058,439 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 192 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 192 | 1956 235 hyd lifters. After it sat overnight I noticed that a few of the lifters that were holding valves open had their plungers collapsed down. Is this normal bleed down from valve spring tension? Thanks in advance. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 |
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2004 Posts: 29,949 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,949 | Lifter bleed-down is normal. All hydraulic lifter engines do it. If there's enough bearing wear and/or other clearance issues that result in low oil pressure, sometimes it takes a little while for the lifters to pump up and stop rattling after sitting for several hours. Jerry
| | | | | Joined: Jan 2015 Posts: 192 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 192 | Ok, that's what I figured, just wanted to be sure. Thanks again. | | |
