1 members (klhansen), 70 guests, and 3 robots.
Topics128,094
Posts1,056,064
Members48,433
#1179054 08/21/2016 5:12 AM
1 Offline
Hellow everyone ,for my 1939 chevy 1.5 ton truck i just put larger lug bolts to fit bigger rims . i went from a 9/16 to a 5/8 bolt on the front only. after driving for 50 miles the front lug nut start to loosen this only started to happen after i did the lug bolt change . i use the same impact wrench and settings for all my vehicles for years , this is the first time i have had any issues. thank you 1pete1
How were the lug studs installed, were they pressed in fully, are you sure of it?
Although you do say "bolt" are they common hex head bolts or pressed in studs? If not studs like original that could be the issue.
Then use a torque wrench and look up the spec for that size lug nut.
Impact is great for removing lug nuts but not so reliable for installing them.
•1952 Chevrolet 3800 pickup
---All pictures---
5/8" lug nuts need about 120 ft./lbs. of torque to stay tight. The purpose of torquing a bolt or nut is to stretch the thread slightly, but not beyond the metal's elasticity. You're probably not tightening the nuts enough.
My 54/55 2-ton GMC COE's 20" wheels have torque-spec of 250-275 ft-lbs (due to them being self-locking nuts).
Grigg, you might recall those wheels/nuts?
10 nuts per wheel: 5/8"-18 in a 7 1/4" circle (I think)
Page 36 in this wheel catalog gives various torque specs for different lug nut sizes and mounting details.
http://www.accuridewheelendsolution...Accuride-Wheels-Product-Catalog-2015.pdf
5/8-18 varies from 130-200 ftlb depending on application
175ftlb might be about right.
Yes Tim, I recall them quite well. That was a long evening taking all those wheels off, backing of brakes, installing new front wheel bearings, and washing and greasing the rear bearings.
---All pictures---
I was reading from the last paragraph on this page in the 1954 Chevrolet Truck Shop Manual.
I bought a heavy-duty (for me) torque wrench for this purpose.
Those self locking nuts are now hard to find so I'm going to guess the OP has plain nuts after only recently upgradeing to the 5/8" hardware.
We need to hear more about the situation at hand.
---All pictures---
