5 members (Gray_Ghost, frogfarmer, Otto Skorzeny, jay d, 50Chevy3100), 52 guests, and 3 robots.
Topics128,056
Posts1,055,804
#1175949 07/29/2016 3:16 PM
Hey Guys,
The body shop guys are hanging and aligning my doors on my cab. Was I supposed to put the door weather stripping on first? I imagine I can still do it but it would be more difficult? Is the weather stripping from most vendors OK to use?
thanks,
Skipper
Yes first. No most does not work fine, at least in my case. Most sell the thick stuff but my doors would not shut. Had to rip it off and get the thin stuff. It is harder to find and way more pricy. I got mine at the fillingstation.com.
It is very difficult to align the doors with the weather strip installed. It is also very difficult to put the weather strip on the door while it is installed. A conundrum wrapped in an enigma.
It would be best to remove the door to put on the weather strip.
I am in the middle of this very process with my painter. We aligned the doors, then drilled holes through the inner door and hinge straps for alignment pins for easy realignment. I will get back to you on whether that works out as planned.
Carl
That is a good idea to drill holes to align. I have not purchase the weather stipping yet so it may have to go on later now.
Skipper, take a look at the weather stripping that Patrick's sells. I have had good luck with it compared to others.
www.patricksantiquecars.com
Matt
Yes, Weather stripping on the doors before alignment. Been there, done that.
Craig
Thanks for the tip. Going to be doing this soon. Steve
Moderated by  ndkid275, Phak1
