9 members (3B, Johnny Rib, baldeagle, 68ironhead, 2-Ton, 1955 1 Series, JW51, Guitplayer, walter74),
108
Mod | | | Forums66 Topics128,038 Posts1,055,471 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 142 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 142 | I have some sil-glyde(from napa) can that be used in place of die electric grease on plug wires?How about the cam lobe for point ignition? It has silicone in it. Any thoughts??? | | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | Dielectric grease is a heat conductor- - - -not an electrical conductor. It's used in places like the heat sink for an ignition module, not like the conductive grease used on light sockets, etc.
The only reason to grease plug wire boots is to keep them from sticking to the porcelain- - - -even wheel bearing grease would work there! Point cams need a high-temp lube that sticks to the surface at speed. Once again, disc brake bearing lube would work great. Most people over-think this kind of stuff!
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | The wire terminal "grease" I have from Truck-lite for preventing corrosion states "not a lubricant"
| | | | | Joined: May 2015 Posts: 11,009 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,009 | The wire terminal "grease" I have from Truck-lite for preventing corrosion states "not a lubricant" Put some between two fingertips and you'll be convinced that it IS a lubricant. FWIW, it will conduct electricity if you put too much on. I tried that on the Injector Driver Module on my Powerstroke and it threw a ton of codes on the scan tool. Wiping most of it out of the connector solved that issue. Of course that runs at over 100V to operate the injectors. At 6 or 12 V it wouldn't really be an issue.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | I have a feeling that many of these "different" greases are very much the same stuff with different labels for marketing purposes. Given the example of the high voltage leakage posted above just illustrates that nearly everything will conduct electricity given enough voltage/amperage behind it. So the question is, does dielectric grease act as a conductor or an insulator? I would say that in a 6 or 12 volt world, with tight/clean connections, the answer is neither. A film of it between tight clean connections gets out of the way resulting in no loss of voltage nor added resistance, while providing corrosion prevention. Let it be known that I have no scientific basis regarding this topic, just real world experience, anecdotal as it may well be. Carl
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Di-electric grease is an insulator that is particularly useful on integrated circuit boards when a component is slid-onto a contact-surface or placed-on/in a contact-connector slot. As 52Carl posted : "A film of it between tight clean connections gets out of the way resulting in no loss of voltage nor added resistance, while providing corrosion prevention." It not only gets out of the way, it allows a metal-to-metal connection and keeps corrosion/oxidation out-side-of the connection/contact point. At high voltages anything will most likely conduct? http://www.wisegeek.org/what-is-dielectric-grease.htmSo, if that author is correct, di-electric grease should not be used between modern-engine spark plugs and ignition-wire ends, especially if it is silicone rubber? The added "conductance" of supposedly conductive metal-containing anti-oxidant greases is also questionable/marginal. They are, however, anti-oxidizing compounds. I use them on all my 6v battery leads connections. | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | I have a feeling that many of these "different" greases are very much the same stuff with different labels for marketing purposes. Given the example of the high voltage leakage posted above just illustrates that nearly everything will conduct electricity given enough voltage/amperage behind it. So the question is, does dielectric grease act as a conductor or an insulator? I would say that in a 6 or 12 volt world, with tight/clean connections, the answer is neither. A film of it between tight clean connections gets out of the way resulting in no loss of voltage nor added resistance, while providing corrosion prevention. Let it be known that I have no scientific basis regarding this topic, just real world experience, anecdotal as it may well be. Carl
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | I just used wd 40 for ever thing and if I really want to make something slick, I grease it... is that wrong..
some things as they get older just need a little more grease to make them last longer or work better.. am I wrong
Carl, are you ok? you just repeated your self..I am worried about you.. Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | I just used wd 40 for ever thing and if I really want to make something slick, I grease it... is that wrong..
Carl, are you ok? you just repeated your self..I am worried about you.. joker, My wife's Granny used to spray WD 40 on her irritated granny skin. She said it worked miracles. Her pet name for me was "Stupid", a nickname well-deserved. As far as repeating oneself, when one is so right, it just begs to be repeated.  That, or I am just one more misstep from suddenly finding myself in a "fabulous, almost-resort-like place that smells funny, and is full of guys which I don't think should be in there either". Carl Carl
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | ok, I buy that.. I am really getting close to the place you speak of.. I almost backed out wife's car out of garage today with out hitting the remote door opener, I was just quick enough to stop when I heard the back up warning device.. never come close to do that but my mind was full of stuff.. crazy.. yrs ago her mom did that and I could never understand how that could happen Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: May 2015 Posts: 11,009 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,009 | Not sure that author is that wise. He also wrote: "Dielectric grease is widely used as a sealant for spark plugs in gasoline or diesel engines, as well as on the gaskets of multi-pin connectors in the electrical systems of vehicles and boats." I've yet to see a diesel engine with a spark plug. I have seen an old diesel tractor with a gasoline starter engine that did have a spark plug, though. In my example, I'm thinking that the dielectric grease I gooped on the connector bridged between the pins and conducted that high voltage. When I cleaned off the face of the connector, that bridge was removed. But I do use dielectric grease on low voltage connectors. I have used dielectric grease on spark plug BOOTS as a sealant, but never saw the need for it on the actual connection. I don't think it would matter if it conducted the 20,000+V of a typical gas ignition system though, because of the short distance between the connector and the spark plug terminal, even if "fully insulated" by the dielectric.
