2 members (Southerntruck, TooMany2count), 72 guests, and 2 robots.
Topics128,089
Posts1,056,116
Members48,434
#1178441 08/16/2016 5:42 PM
I've got my original Delco Remy horn mounted on the intake manifold to sound on my '49 Chevrolet 1/2 ton. Questions: How much spark should I see from the points? I have a slight spark from the points right now. What should the air gap be between the diaphragm and front plate? The front plate is about 1/16" from the diaphragm at this point. Anyone have the specifications for setting the proper point setting and air gap on these horns?
Tim
1970 VW Beetle
One method........keep adjusting until it sounds right.
At one point I hooked mine up to a battery charger. The pulsing DC from the charger caused the horn to work after a fashion. This gave me hope because I could make it come alive. I then experimented with the point adjustment.
1951 1 Ton Completed
47-52 standard-horn adjustment - as described above by showkey & truckernix.
Thanks guys! I GOT IT. Adjusted the points with a multimeter. Set it to ohms, placed probes on the positive and negative terminals and got the points set at 0.5 - 0.8 ohms and the sound is GREAT!!
Tim
1970 VW Beetle
