| | | Forums66 Topics128,042 Posts1,055,515 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 15 New Guy | | New Guy Joined: May 2005 Posts: 15 | Hi there I am new member looking for some info. Its been a while since I had some chevy truck to play with. I have inherited what i belive is a '53. The body is rough but I have replacement fenders. The problem is the cab. She is pretty rough . Is any cab from a 47-53 interchangeable ? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes the 47-55 1st cabs all mount the same - differences in details
Bill | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | What that means is that if you get the older style cab, there would not be mounts in the correct place at the back. I also think the for the first year or two, the gas tank was not in the cab. | | |
