4 members (Steelonsteel, Gray_Ghost, TUTS 59, 1 invisible), 179 guests, and 0 robots.
Topics128,109
Posts1,056,268
Members48,439
Putting in headlight parts on my 3100 and I have these round seal strips with wire inside but can not find any instruction on installation in any of my manuals. hope someone can help..
1951 chevy 3100 short bed frame off resto.
If you're asking how the seals install, they're held in place by the wire clips to the front edge of the bezel. If I remember, I can take a couple of photos and post them up for you of the bezels I have laying around in my garage (which hasn't seen a complete vehicle in over a year - just various pieces.)
I tried to install them and gave up!
Photos would be great!
Here you go
back of headlight bezel
closeup of top clip
top clip undone
gasket at bottom
This one has the original wire style clips. Notice that the top clip is different in that the open ends hold the gasket in place. The other three (sides and bottom) use the closed end to hold the gasket and the open ends snap under the outer edge of the bezel. The last photo shows how the gasket laps over the front of the bezel.
Good you sent the pics because I thought the seal went between the bezel and fender!
Thanks to all for the seal placement info, now that I have the seal installed on the bezel it will not fit over the installed headlight. any one else run into this problem!
Dang! I didn't even know there was a seal. I've replaced my headlights (which had no seals) without seals, and they're doing fine.....Now my OCD is gonna bug me until I put seals in the dang thing..AARGH...Thanks guys!!!!!!
The reproduction ones are a bear to get to fit. If I can't find a decent original, I go without one at all and haven't had any troubles. I am not sure what they do to begin with. Someone out there must have that answer.
Carl
