fenders and running boards will be a semigloss black. The plan for now is a dually stepside if I can get the rear tires under the 2" wider fenders from Superior. long bed since is on a ton chassis, may be same frame as a 3/4 ton in 46 -- not sure. It had a full floater 8 lug with singles on it when I got it.
