2 members (TUTS 59, Ponchogl), 106 guests, and 2 robots.
Topics128,035
Posts1,055,564
I pressure tested my radiator (re-cored @ 25 years ago according to PO). First test was at 6 psi and had no leaks. So I bumped it up to 10 psi and discovered 2 leaks about 8 inches up from the bottom tank.
I brought it to the local radiator shop for repair and their pressure test at 4-7 psi did not show any leaks.
He said the flow was good also and I could probably get several more years of service out of it.
Is 10 psi too much for a proper test on a 1950 radiator?
Jackie
That's approaching the point of a blowup. Those old cores were not designed for high pressure and you're courting disaster with over 7 PSI or so. If you want a little leak insurance, run plain water in the radiator with a few ounces of Sodium Silicate (water glass) in it for several heat cycles. When I drove the fire truck with the big 502 GMC engine to KC last year for Ed Pruss, I sealed a minor head gasket leak with water glass. He told me recently that it's still holding, even after driving it on to Denver and adding antifreeze to it. I believe that system has a 4 or maybe a 7 pound pressure relief built into the top tank of the radiator.
That was a really interesting trip!
Crusing in the Passing Lane
Jerry,
Thanks again.
Ed
The radiator shop found no leaks even after my 10 psi challenge, what is the likelihood that I damaged something?
Jackie
if it's not leaking, it's not damaged, just stick to the normal 4-7# cap and get on with driving it til something breaks wink
