4 members (Stovebolt48, 55shaker, HelmutVonSchet, Otto Skorzeny), 65 guests, and 1 robot.
Topics128,079
Posts1,055,941
Members48,430
#1177756 08/11/2016 10:26 PM
I have a 53 Chevy truck with a 1956 Chevy 235 can u replace the rear main seal and pan gasket without pulling the motor out of the truck ?
sal moreno #1177760 08/11/2016 10:42 PM
Sal,
Yes you can replace the rear main seal and oil pan gasket without removing the engine from the truck. Get a Sneaky-Pete tool and remove the rear main seal cap. The bottom seal is in the rear main cap. Don't lose the shims!! Remove the upper rear main seal with the Sneaky-Pete tool. You can also install the rear main seal with the Sneaky-Pete tool. Oil the rear main seal well and take your time with the install. Be careful not to twist the seal and don't score the seal seat. Re-torque the rear main cap to the shop manual specifications. The oil pan should drop down with a little persuasion. Install the oil pan gasket with yellow trim adhesive to the pan. Let it dry. Make sure the engine surfaces are REALLY clean before you reinstall the pan with the new gasket. Don't over torque the pan bolts. A little petroleum jelly on the oil pan gasket going to the engine will help seal the cork gasket and make it easy to position the oil pan.
Hope this helps.
Tim
1970 VW Beetle
fixit1958 #1177767 08/11/2016 10:49 PM
Thxs for the great info
Riding in the Passing Lane
There is a modern rubber type seal available for that engine.
1972 Chevy c10 Cheyenne Super
Who is the vendor and what is the part number?
My Blog
Good seal. Has worked for 2 years in the 235 in my truck. A trick some one here pointed out: push the seal about 1/4 inch past the main bearing seat. It is stiff enough and keeps the seam from matching the up with the bearing seat joint. The main bearing cap will slip over the raised end just fine. A dot of weather strip adheasive on the exposed ends and no leaks in 15,000 miles. Works!
Steve H
Dave,
What years 235s (and, 261s) will that work on?
If you're doing an out of the frame major overhaul, it's also possible to machine the block for a full-circle lip seal that will positively eliminate rear main oil leaks. I believe the same seal that fits a Ford V8 Diesel works for the stovebolt engines.
Dave,
This seal is not designed to work on an engine with shims on the mains.
Chev used shims on the mains till mid 1955.
There are shims listed in the parts book for later engines, but I have never seen them in a engine.
I think they are listed for use in engines where the journal dimensions are off slightly.
My Blog
Thanks, Dave,
That is what I thought
