| | | Forums66 Topics128,035 Posts1,055,559 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2015 Posts: 135 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 135 | I pressure tested my radiator (re-cored @ 25 years ago according to PO). First test was at 6 psi and had no leaks. So I bumped it up to 10 psi and discovered 2 leaks about 8 inches up from the bottom tank. I brought it to the local radiator shop for repair and their pressure test at 4-7 psi did not show any leaks. He said the flow was good also and I could probably get several more years of service out of it. Is 10 psi too much for a proper test on a 1950 radiator?
Jackie
| | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | That's approaching the point of a blowup. Those old cores were not designed for high pressure and you're courting disaster with over 7 PSI or so. If you want a little leak insurance, run plain water in the radiator with a few ounces of Sodium Silicate (water glass) in it for several heat cycles. When I drove the fire truck with the big 502 GMC engine to KC last year for Ed Pruss, I sealed a minor head gasket leak with water glass. He told me recently that it's still holding, even after driving it on to Denver and adding antifreeze to it. I believe that system has a 4 or maybe a 7 pound pressure relief built into the top tank of the radiator.
That was a really interesting trip! Jerry
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 |
| | | | | Joined: Jul 2015 Posts: 135 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 135 | The radiator shop found no leaks even after my 10 psi challenge, what is the likelihood that I damaged something?
Jackie | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if it's not leaking, it's not damaged, just stick to the normal 4-7# cap and get on with driving it til something breaks  Bill | | |
