| | | Forums66 Topics128,128 Posts1,056,668 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 6 Junior Member | | Junior Member Joined: Sep 2005 Posts: 6 | I may have wrong sills (49.5 in.long),or wrong front bed plate(new from chevy duty)or too much fun in the 60's or all of above. The 1st. sill holes does not line-up to be bolted with the front bed plate holes(9 of them on leading edge of shelf for bed boards,they are facing rear of truck).The two holes on one side of sill look like they should be in play but do not line-up with holes in front bed plate! Take one dollar for this relaxing hobby truck right now!! | | | | | Joined: May 2005 Posts: 27 Junior Member | | Junior Member Joined: May 2005 Posts: 27 | I'm getting ready to do the same thing on my 49, hope you get some good info, I'll keep up with this post.Every thing I've gotten on this site has been really helpful in my first try. Manfighter16 | | | | | Joined: Sep 2005 Posts: 6 Junior Member | | Junior Member Joined: Sep 2005 Posts: 6 | Hey manfighter16,finally fiqured my 1st cross sill out,I had two different sets of sills and they both were wrong years!Got new one from Chevy Duty($25)wtth 9 holes on one side and it went fine. Use set of holes all the way through frame,at about half-way even with frame webbing right behind cab,put the longest bolts through sill(with holes in side toward cab)then wood spacer,then lower hole in frame. Line up 9 holes in sill with 9 holes in front bed plate.Finished. | | |
