8 members (rfs56trk, Frank50, BarryP, Gazz, UtahYork, Jon G, Ole49GMC, 1 invisible),
106
Mod | | | Forums66 Topics128,134 Posts1,056,740 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2016 Posts: 5 New Guy | | New Guy Joined: Jul 2016 Posts: 5 | First post so beat me up gently. Trying to restore a 59 Apache back to factory specs, minor upgrades along the way. I've just ordered a pre bent 7 piece kit and was hoping someone has pictures or diagrams of this. the kit just doesn't seem to match up, I've got the factory assembly manual but not the supplement one. any guidance would help! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | there was different flavors of routing thru the TF years, and maybe among different assembly lines as well .... rear axle 'splitter' might be on drivers or pass side, and front/rear split is sometime on pass side, best bet is.... punt  or you could try matching various line lengths at a FLAPS and bending them yourself Bill | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Section 5, page 1 (page 315) should give you a basic idea on how they were routed. However, as Bill mentions, there were not only running changes, but also differences from plant to plant.
Bill Burmeister | | | | | Joined: Jul 2016 Posts: 5 New Guy | | New Guy Joined: Jul 2016 Posts: 5 | thanks fellas, ive been scratching my head while looking at the drawing on pg. 315 for the last couple nights. While tearing down the old truck there were a few complete lines that i saved and have matched up with the new line but that was only 3/7. phone got soaked and lost pic of deconstruction :/ but i remeber one line running across the engine cross memeber? still green but whats FLAPS?
| | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | FLAPS.. Friendly Local Auto Parts Store
yes, there should be one running across the back side of the front crossmember feeding the RF wheel. | | | | | Joined: Jul 2016 Posts: 5 New Guy | | New Guy Joined: Jul 2016 Posts: 5 | would it be odd that there isnt a BL bracket in front of the rear axle hump on the frame? | | |
