3 members (Shade Baby, Peggy M, 1 invisible),
107
Mod | | | Forums66 Topics128,087 Posts1,056,340 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 264 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 264 | So after cleaning out entire fuel system due to debris, had to get gas. Almost at station oil pressure dropped to zero (has been rock solid 30 to 35 psi) and heard a sound like a loose gear as we shut it down right away. Haven't yet dropped to pan to check, but think its just the oil pump???? Will be pulling motor, but had hoped to wait few more months before doing that. 1952 Canadian 3 ton with a 1973 292. | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Before you drop the pan, just check to see that the distributor has not backed out enough to disengage from the oil pump drive. After that, remove the distributor and turn the oil pump shaft with a screwdriver. If it doesn't turn, turns but "lumpy", spins free with no resistance, obviously bad pump. If it seems to turn normally, spin it with an electric drill and see if you get pressure. | | | | | Joined: Feb 2004 Posts: 29,826 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,826 | Check the bottom of the distributor shaft to see if the flat drive tang for the oil pump has sheared off. With the noises, it's more likely an internal failure in the pump. Getting the oil pan off might be a challenge. On the smaller trucks, supporting the frame on jack stands and letting the axle hang down gives a few inches more pan clearance- - - -not sure if that will be necessary on a big rig.
Another possibility is that the oil pickup screen has come adrift and the crankshaft is hitting it. Jerry
