4 members (Otto Skorzeny, Gib70, Uncles51, Leo), 136 guests, and 3 robots.
Topics128,164
Posts1,056,977
Members48,458
GTO
Offline
I recently acquired a 1939 Panel Truck (in pieces!). Does anyone have photos of the rear mounting brackets, etc. to mount the body to the frame or any idea where I might find/purchase a body assembly manual? Thanks in advance for any assistance.
GTO,
Welcome to Stovebolt.com.
I doubt you will get a response from someone with an assembly manual, but, that is a good question.
You have a somewhat rare truck - check out the "Gallery" (it is listed in the menu at the top of this page). If you find a member with a truck like yours, contact them in a Private Message or an email message. However, you will not be able to contact anyone until you have made 4 more approved posts (your first post has been approved).
Submit a few posts telling us about your truck, or about what you need/want to do to your truck, or other questions/comments.
FYI: You posted two similar posts. One was deleted.
GTO
Offline
Thanks for the info. I'm having a difficult time finding much information on the '39 at all, but your idea is a good place to start.
Hi GTO,
Try contacting GMHeritagecenter.com. They have helped me in the past. They may even be able to give you the history of your burb if you supply them your vin number.
https://www.gmheritagecenter.com
Russ Sweet
GTO,
Send me a personal email--I just completed a 1938 3/4 ton panel, all original.
JM
GTO, I have a 1939 Suburban and can tell you the rear mounting block is 2 3/4" wide x 3 3/4" long x 1 3/4" high. I made mine out of oak, copied the old original block. The bolt goes thru the hole in the rearmost chassis crossbar.
e-mail me for photos. [email protected]
