| | | Forums66 Topics128,018 Posts1,055,342 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | Was working on my bedsides today and noticed a problem with a rear stake pocket I got from JC. The only holes in it besides the hook hole were the ones for the tailgate hinge. On the replacement stake pocket, the holes were 1/4 inch too low, which would make the tailgate hang crooked. They'll need to be welded shut, redrilled and the upper nut welded in place. Good thing I found it before welding it to the bedside, as it would have been harder to fix then. Here's a couple pix of the problem. original stake pocket & hinge holesReplacement stake pocket & hinge holes
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2005 Posts: 406 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 406 | Before you cut and weld, check the position of the hinge bolts measuring down from the top bend of the bedside. It looks like that new stake pocket may be a bit shorter on the very bottom which would throw off your measurements from the bottom. We use that top bend for reference when punching the holes. I don't know if that is a Mar-K stake pocket or not. We usually punch the holes for attaching to the rear sill unless customer specifically requests they be omitted. | | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | Thanks I did check it with the bottom lined up with the original bedside with the pocket attached and it fit well to the top bend. I also measured from the top of the chain hook slot and it was long between there and the top hinge hole. The notch at the rear bottom isn't right either, being about 1/2" off. That may be what you were referring to. Here's a pic of the two sitting side-by-side stake pockets
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Not related to the problem but I notice the upper interior corners in the new pockets don't look pressed clean and square like the original, is this so? Are any of the reproduction stake pockets indistinguishable from original?
Girgg | | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | Not related to the problem but I notice the upper interior corners in the new pockets don't look pressed clean and square like the original, is this so? Are any of the reproduction stake pockets indistinguishable from original?
Girgg Yeah, the new stake pocket corners are a bit more rounded than the original. Not going to be that noticeable once installed though. I got that one thru JC.
