7 members (TUTS 59, Gray_Ghost, panic, tclederman, Peggy M, MRMEROTH11, Wickedbass), 122 guests, and 0 robots.
Topics128,068
Posts1,055,880
Members48,428
#1176417 08/01/2016 9:24 PM
Z
Z Offline
the tranny in the 53 1/2 ton is pretty noisy and grinds when down shifting into 2nd from 3rd.
Are these transmission worth rebuilding ? Are there even parts available ?
IF parts are available, who has them ?
Am I best off putting in a more modern 3 speed tranny. I have a floor shifter now.....
Do I need to get rid of the Torque tube driveline to go with a new tranny ?
Thanks....J
1953 chevy 1/2 ton with 3 speed 318 on floor and 1955 235 engine
the parts are available, some thru vendors, parts suppliers, and some on eBay. I was fortunate to find mine on ebay years ago. so watch prices
Mike
Crusing in the Passing Lane
That trans would be an SM-420, parts aviable. Novak in SLC.
Ed
Z
Z Offline
What would be a good more modern updated standard tranny to use in my 1953 1/2 ton to replace the old tranny I now have. I am not sure I want to rebuild the old one as it is geared quite low. (granny gear)
For anyones info: Obsolete Chevy parts, now bought out by Jim Carter truck parts, used to show the nessacary gears in their catalog, so I'm wondering if Carter has the gears etc. for sale
Just a thought Mike
Modern(?) 465's have a higher granny gear than 420's, although one might not notice the difference.
Ed
More modern than 1954?
You'd be going from an enclosed drive-shaft to an open driveshaft?
You'd need a different drive-shaft, rear end, and rear springs?
Z
Z Offline
Looks like I will be rebuilding the existing tranny.....
Call Novak.
Ed
Z
Z Offline
THANKS....WILL DO....
You say floor shift. Is that a converted 3 speed or a four speed?
My Blog
Z
Z Offline
When I got the truck it had the 3 speed floor shift which I know was not available in 1953, but the engine is out of a 1955 Chevy so maybe the 3 speed is from 1955 ?
I will be overhauling the tranny this winter and then will find out exactly what I have.
