| | | Forums66 Topics128,151 Posts1,056,989 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 306 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 306 | ** Need to know if the spare tire carrier for a 53 Suburban would be the same as what one would find on a 53 3100 pickup?? Thanks | | | | | Joined: Sep 2015 Posts: 96 'Bolter | | 'Bolter Joined: Sep 2015 Posts: 96 | I know it's an older thread, but my 52 spare carrier is a little different. I have the same lower arm and bolts that hold the tire, but I have 2 of the smaller "c" channels that are bolted/attached to the upper rail of the frame. Can send a pic if needed. I'm in process of figuring out how to use the carrier since I put in the exhaust and a trailer hitch. ):
azcornman | | |
