4 members (Jon G, Gray_Ghost, Bill Hanlon, MRMEROTH11), 85 guests, and 0 robots.
Topics128,068
Posts1,055,881
Members48,428
#1176267 07/31/2016 5:54 PM
Yep, you read that right! Check it out.
http://vccachat.org/forum/ubbthreads.php/ubb/showflat/Number/347535
Cheers, Dean
Dean 'Rustoholic' Meltz
Lurch: 1927 1-Ton Chevy Cattle Truck
Old and ugly is beautiful! -- The Saga
Lurch's Gallery
Justin: 1928 Chevrolet AB Canopy Express
That engine is just too cool! yahoo
More like Two cool....
It's just someone's home made job cutting a 4cyl in half. Chevy used 4 cylinder engines through 1928 when the 6 came out. They also used a V8 in 1917-18 which must be quite rare by now, I've never seen one.
1952 Chevrolet 3800 pickup
---All pictures---
Anybody ever seen a 4 cylinder engine turned into an air compressor on two cylinders? Lots of Model A's were converted that way, using the whole front end- - - -front axle, gas tank, radiator, hood, etc. with a trailer hitch attached instead of a front bumper. A special intake and exhaust manifold ran the engine on cylinders 1 and 4, and 2 & 3 compressed the air with the exhaust valve disabled and a one-way check valve where the spark plug used to be. The 2 & 3 intake valves had very weak springs that let every down stroke draw air into the cylinder, and every upstroke compressed. Lots of jack hammers got powered by those rigs- - - -relatively low pressure, but lots of volume.
Bhudda likes it!
Grigg, I have a picture of the v8 Chevy engine. I don't post pics to this site as it's just too much trouble. I'll try to PM it to you.
I don't doubt they exist as I've seen a few pictures in books and such, but never one in person much less in a car running. They must be uncommon.
---All pictures---
I have seen WW2 Jeep engines converted to air compressors.
Neat little 2 cylinder.
Lots more pictures
WRT Chevy 2-banger: good mechanic, bad engineer.
What they made has "one up & one down" and is horribly out of balance, and has that same soothing offset exhaust note as a 350 Honda... until something breaks.
A better choice (but much more difficult) would have been to use the 2 center cylinders which are "both up" (same piston position) like a British twin.
A common Smiths industrial compressor (on its own trailer) is a converted Ply-Do 230" flathead L6.
I have some old 2 cylinder industrial engines, newer than "hit and miss" engines but not a lot newer. One make, LeRoi, has pistons that both travel up together, and the other, Novo, has one up one down. They're both reasonably smooth and run nicely but the one up one down engine jumps around less.
---All pictures---
V
V Offline
Anybody ever seen a 4 cylinder engine turned into an air compressor on two cylinders? Jerry
Back in the 70's at Cherry Point we had an old Shrade (I believe) branded 6 cyl tractor with 2 cyl's modified into an air compressor. It looked factory. It ran (barely) but I don't recall how much air pressure it made. we had a lot of WWII and Korean War era gear intermixed with modern (for the 60's/70's)gear.
We had some pretty wild multi-tasking GSE gear back in the day.
Navair required we be prepared to operate and service aircraft in any environ sans modern utilities....
Wish I had accumulated some of that very flexible rock solid machinery now LOL
re. Chevy 2 cyl engine. Cool find.
In a kinda related post, after listening to that linked modified 2 cyl flathead Model T engine and it's sound,
I am looking to add an old hit and miss engine as well as an old JD Johnny Popper to my collection one day. Theres something about their sounds that are, entertaining LOL
Dave
Lurch's Gallery
Well now you need to find a way to put it to work. An ice cream maker?
Frankie has a new home! I donated him to the Antique Gas and Steam Engine Museum near San Diego.
Here are the details: https://vccachat.org/ubbthreads.php/topics/381189/re-1925-26-chevy-2-cylinder-motor.html#Post381189
On to the next project! Dean
Lurch's Gallery
Not to get too off track, several years ago I saw a 1917-18 Chevy V8 running and driving at the Newport, Indiana Hill Climb. I did not get an opportunity to study the motor, but I did see it. I did not see it go up the hill, but it may have.
Speaking of compressor conversions, I have read of Flathead V8 Fords being modified this way.
Professional Novice
About 40 years ago a friend out in California ran a sandblasting rig with a compressor-converted flathead V8 on it. We installed a 4" stroke 49-53 Mercury crankshaft to replace the 3 3/4" Ford shaft, to give it a little more volume.
