5 members (Wally / Montana, Chris's 46 / 515, mick53, Stovebolt48, 1955 1 Series), 133 guests, and 3 robots.
Topics128,189
Posts1,057,337
Members48,469
#1176281 07/31/2016 9:12 PM
V
VEW
Offline
V Offline
Hi Folks,
I'm in the process of putting an R10 overdrive in DoughBoy (55 Grumman). I got a complete transmission (62 truck), but after disassembly and inspection, the cluster gear is a concern. So, I just pulled the SM318 from DB, which looks good.
Everything is ready to be reassembled, with a rebuild kit to arrive tomorrow. With the help of all of the information on this site, and the help of a good friend, I think I have everything I need.
Except for one thing. Is there some kind of special bolt that goes on the OD lever on the transmission? It's the one the end of the OD cable gets attached to in order to put IN and OUT of OD.
As always, thanks for your help.
~ Victor
1957 3100 - moved on
VEW #1176287 07/31/2016 9:53 PM
V
V Offline
I had the same question. I couldn't find the answer so I ended up taking a large pin with a head on it that had holes drilled in the sides of it and tapping it. Then I used some washes and put two jam nuts on the end. It worked, but I'd rather have it the way it's supposed to be. I saw a picture of one on youtube that had a bushing in the hole on the arm and a pin through it that had a hole in it for the cable and a nut on the end of it.
VEW #1176289 07/31/2016 9:58 PM
V
VEW
Offline
V Offline
Thanks for the info.
"Necessity is the Mother of Invention"
~ Victor
VEW #1176308 08/01/2016 12:48 AM
V
V Offline
I found a picture I took of when I made it just for reference.
http://i156.photobucket.com/albums/t24/vetteman61/1957%20Chevy/IMG_1501_zpsihlli4ru.jpg
VEW #1176328 08/01/2016 2:31 AM
P Online: Content
My Blog
VEW #1176373 08/01/2016 3:22 PM
V
VEW
Offline
V Offline
Thanks Dave, that helps a lot. I'll look around for one of those brass (shoulder?) bushings and see if I can't put something together.
~ Victor
VEW #1176513 08/02/2016 3:02 PM
V
VEW
Offline
V Offline
I was unable to find that brass shoulder bushing at NAPA or LAPS or hardware store, so I searched online and came up with this:
shoulder bushing
I will need to reduce the oal, but if that's all I need to do to make it work, I'm happy. I ordered 5 of them, just in case.
Follow up: The bushings didn't work out. Too much play in it. So, I just fabricated one from a brass reducer, which I should have done it the first place. Works just fine.
~ Victor
VEW #1176518 08/02/2016 3:44 PM
Camp Commandant
Camp Commandant
Victor, does it have to be brass?
http://www.mcmaster.com/#shoulder-bushings/=13jtx01
I'm actually surprised MCM doesn't have them in brass, and every other type of metal too.
~ Billy
1959 GMC 860 | Pictures
VEW #1176520 08/02/2016 3:51 PM
P Online: Content
The bushing is steel,not brass, but brass would be fine.
My Blog
VEW #1176522 08/02/2016 3:54 PM
V
VEW
Offline
V Offline
Thanks Billy, but it seems a plastic bushing would wear sooner, causing a reduction in the "swing" of the OD lever. Don't know for sure.
Dave's pic shows a brass one. DB is not completely "original", as you know. But I usually try to keep them that way if I can.
Thanks again.
~ Victor
VEW #1176591 08/03/2016 2:48 AM
P Online: Content
In case you missed it above.
The bushing is steel, not brass, but brass would be fine.
My Blog
