| | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2012 Posts: 158 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 158 | What is the best 16" (budd wheel) to replace the split ring wheels on my 1970 C-30? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Single or dual?
There are lots of choices, finding some you like at a junkyard might be most economical. | | | | | Joined: Apr 2012 Posts: 158 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 158 | C-30 Dual in rear....Not as easy as you might think...There's Hub centric, back spacing, counter sunk & flat lug holes....Also the diameter if the lug stud...Just looking for the best option to transition from split rims to regular... | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Look at a slightly newer GM 8 lug dual wheel truck. You want hub centered and flat, not countersunk.
If you come get them I have 4 from a P-30 GM bread truck step van and you're welcome to them. | | | | | Joined: Apr 2012 Posts: 158 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 158 | Appreciate the offer...Your kinda far...I'll keep playing with it...To make matters worse someone before I had the truck, took the front hubs off & installed 16.5 wheels from a 3/4 ton...I finally was able to find replacement hubs, so I can get it back to where it should be...Slowly I'm getting all the rube goldberg problems ironed out. You would have thought this truck came from Cuba. Thanks again... | | |
