6 members (Gdads51, artinva, Otto Skorzeny, VicZ, klhansen, RAC1812), 49 guests, and 0 robots.
Topics128,077
Posts1,055,928
Members48,430
0
0 Offline
What is the best 16" (budd wheel) to replace the split ring wheels on my 1970 C-30?
Single or dual?
There are lots of choices, finding some you like at a junkyard might be most economical.
1952 Chevrolet 3800 pickup
---All pictures---
0
0 Offline
C-30 Dual in rear....Not as easy as you might think...There's Hub centric, back spacing, counter sunk & flat lug holes....Also the diameter if the lug stud...Just looking for the best option to transition from split rims to regular...
Look at a slightly newer GM 8 lug dual wheel truck.
You want hub centered and flat, not countersunk.
If you come get them I have 4 from a P-30 GM bread truck step van and you're welcome to them.
---All pictures---
0
0 Offline
Appreciate the offer...Your kinda far...I'll keep playing with it...To make matters worse someone before I had the truck, took the front hubs off & installed 16.5 wheels from a 3/4 ton...I finally was able to find replacement hubs, so I can get it back to where it should be...Slowly I'm getting all the rube goldberg problems ironed out. You would have thought this truck came from Cuba. Thanks again...
Moderated by  Dusty53
