6 members (R&S 51 GMC, Wrenchman, Swami29, Shade Baby, Otto Skorzeny, KEVINSKI), 103 guests, and 0 robots.
Topics128,125
Posts1,056,339
Members48,440
#1175297 07/24/2016 10:03 PM
A bit embarrassed here. I have misplaced ( can't find ) a container that had bell housing to block bolts, transmission to bell housing, flywheel to crank and pressure plate to flywheel bolts all on original '49 with original 216 engine and 4 speed. Would appreciate any help as to lengths, size, and thread types.
Dave
Crusing in the Passing Lane
Probably .375" x 16, get a few sizes from the hardware store and try them out, coarse thread, too long so can figure out length.
Ed
I usually find my missing bags of bolts by either blaming my wife for throwing them out, or by purchasing new ones. Either method will often make the lost bag show up before I have a chance to install the new ones. You can try to just go to the hardware and buy random hardware. I don't know that the lost parts gremlin is astute enough to know the difference. smile
BTW the flywheel-to-crank bolts have very shallow heads on them, to prevent interference with the clutch disc. I believe that 350 flywheel bolts will work. Make sure to use blue Loctite on the threads to hold them in place and to prevent oil leaks.
Carl
