5 members (Uncles51, 55shaker, Woodcmiami, Stovebolt48, joe apple), 65 guests, and 3 robots.
Topics128,021
Posts1,055,351
Members48,420
Page 2 of 2 1 2
wodniw5 #1174774 07/20/2016 8:52 PM
Hey, at least you gave it a good try. Sometimes we all need to know when to throw in the towel and get professional help that can lay hands on the truck. We are fortunate here on Stovebolt to have several professional mechanics who are willing to pass along their vast knowledge. Unfortunately they can't normally touch what we are asking them to fix. Hope you get it back soon and running like a top. Please let us know what your mechanic finds, even if it's so simple it was embarrassing. drive
wodniw5 #1174806 07/21/2016 2:17 AM
Good plan, Hoss! One good thing will be, finding out what the causes of the problems are so you/we will know where to look when we have similar symptoms.
My bet is that you have two malfunctions going on at the same time. This is the toughest scenario to diagnose.
Carl
wodniw5 #1175173 07/23/2016 9:57 PM
Final Update I hope:
The problem was simple and embarrassing but I don't care I just drove the truck down the road and I don't know who was happier me or the truck.
Took the mechanic all day Thursday to find the electrical problem. It turns out the ignition wire from switch to positive side of the coil was burnt or broken on the inside thus the intermittent spark no spark readings.
Then once they got that fixed the vacuum advance was not working correctly from one of the carbs and fuel was building up. I had a spare carb and installed this morning and it's all good.
I must say that the Fenton headers and the new dual carb set up make quite a difference in the way she runs and sounds.
Thanks so much for all the help and advice.
Paul
wodniw5 #1175191 07/23/2016 11:37 PM
No reason to be embarrassed about it. Intermittent short can be the roughest diagnostic problem to solve, as seen by your mechanic taking a full day to find and fix. Now it's time to just drive the wheels off her. drive
wodniw5 #1175293 07/24/2016 8:47 PM
I see you are still looking to rebuild your carbs??
Redryder pix
My Hotrod
wodniw5 #1175295 07/24/2016 9:45 PM
the 51 is one running well so time to start on the rebuild of my 52,that's what I need carbs for.
wodniw5 #1175299 07/24/2016 10:24 PM
nice, you got two trucks..
Redryder pix
My Hotrod
Page 2 of 2 1 2
