| | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2016 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: May 2016 Posts: 42 | When I bought my truck it had a small after market steering wheel on it. After doing a little research on what a more correct steering wheel would be (not enough research as usual) I found a nice original wheel for sale for fairly cheap, and also picked up a Chevy truck horn button. The wheel was missing the chrome horn ring, so I did a little more research and found out that it is a '60s Malibu wheel. I ended up finding an original horn ring and got it put on. My question is, because the Malibu horn button is bigger, is there any sort of adapter that will work with the truck horn button I have? Or is there a plain Chevy button that fits better? The button I have has the rubber ring sticking out from the back, but the Malibu has the two cutouts for the spring clips.
'If you want to test out a truck, buy your own dang truck!' -CSM Fulk, Iraq
| | | | | Joined: May 2016 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: May 2016 Posts: 42 | Answered my own question. Found a horn button retaining cup that should work. Will see when it arrives.
