11 members (Jay R, wilbur53, Gdads51, TUTS 59, DaveV, RLB, WICruiser, Phak1, Otto Skorzeny, 55shaker, 1 invisible), 109 guests, and 4 robots.
Topics128,056
Posts1,055,789
#117491 08/23/2005 7:01 PM
Junior Member
Junior Member
What problems will I have putting my 49 bed on a 54 frame? The body fits great.Manfighter16
#117492 08/23/2005 7:42 PM
The rear part of the frame changed in 1954 from previous models due to the new box design. The kickup over the rear axle was reduced eliminating the wood blocks and the box was a little deeper with flat top rails. The only complication should be the right thickness of blocks to make it look right and match up with the splash aprons. Maybe somebody that has done it will chime in. Good luck.
Curt B.
You Tube
#117493 08/23/2005 8:56 PM
Anonymous
Unregistered
Anonymous
Unregistered
You can do it but you will have to use the spacer blocks in the rear in addition to the front. You may also have to change the side splash aprons between the bed and the running board to the 54-55.1 model to have it connect properly to the running boards.
#117494 08/24/2005 2:51 PM
Junior Member
Junior Member
Thanks guys, I think I'll just put the box together and check the spacing. Manfighter16
