1 members (baldeagle),
89
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 103 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 103 | Ok So I have Bendix 3 3/8 disk brake calipers all around on my 51 COE. I have 1.25 master cylinder bore mated to a hydroboost. So, My question is what size brake lines do I run from the master cylinder to the distribution block, then from the distribution block to each caliper? Thanks Chris | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I'd probably run 3/16 to each front caliper and over the rear axle. 1/4" for between MC and proprotioning valve and to the rear axle.
Use an original modern truck with similar/same components as your guide, what did they use? May as well benefit from GM's engineering. | | | | | Joined: Sep 2012 Posts: 103 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 103 | Grigg, Thanks Thats my next step, trying to locate a modern with like parts Chris | | |
